Import contacts from a CSV file
You can import contacts from a CSV file.
Make sure that the columns of your CSV file are linked to existing columns in Bricsys 24/7:
  • First name
  • Last name
  • Email
  • Function
  • Organizations
  • Address
  • Postal/Zip code
  • City
  • Province/State
  • Country
  • Phone
  • Mobile
  • Fax.
  1. Click Address Book in the toolbar.
  2. Select the applicable address book in the tool menu.
  3. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  4. Click Import from CSV.
    The Import as CSV file in internal address book window appears.
  5. Click Select a CSV file.
    A modal window appears.
  6. Select the CSV file you want to upload.
  7. Click Open (Windows) or Choose for Upload (Mac).
  8. Click Next.
    The Import contacts using a CSV file window appears.
  9. Check if the values of your CSV file are mapped with the right values in Bricsys 24/7.
  10. Click Import.
A pop up window informs you that the contacts are successfully imported from CSV.
