Keyboard shortcut overview
Keyboard shortcuts that you can use in the content pane:
| Keyboard shortcut | Description |
| Ctrl + A | Click on the content pane, and use Ctrl + A / Command + A to select all items in a window. |
| Command + A | |
| Shift + click |
Click on a checkbox in a list, hold down the Shift key, and select a second checkbox. The checkboxes that are between the 2 checkboxes will also be selected. |
| Esc | Deselect all selected items in a window. |
