Keyboard shortcut overview
Keyboard shortcuts that you can use in the content pane:
Keyboard shortcut Description
Ctrl + A Click on the content pane, and use Ctrl + A / Command + A to select all items in a window.
Command + A
Shift + click
Click on a checkbox in a list, hold down the Shift key, and select a second checkbox.
The checkboxes that are between the 2 checkboxes will also be selected.
Esc Deselect all selected items in a window.
