You can consult an overview of folders synchronized between Bricsys 24/7 and LetsBuild:
Click Administration
in the toolbar.
Click Project setup.
Click the ellipsis button
at the top of the content pane.
A context menu appears.
Click Synced folders overview.
The
LetsBuild synchronized folders overview window appears. The number of synced folders is displayed.
Tip: Click on the column header to sort the folders.
If you want to unsync a folder:
- Hover over a folder.
- Click the X icon.
The Unsync folder window appears.
- Click Unsync to confirm.
Click Close to close the window.
