Move a workflow You can move a workflow: Click Workflows in the toolbar. Select a workflow folder in the tool menu. Select a workflow in the content pane. Click the ellipsis button at the top of the content pane. A context menu pops up. Click Move. The Move workflow(s) window appears. Select the folder(s) you want to move the workflow to. Tip: You can move the workflow to the current project or a different project. If applicable, edit the name, and enter a description. Click Move. A pop up window informs you that the workflow is successfully moved.
