Print to PDF
You can print one or more documents to a PDF:
  1. Click Files in the toolbar.
  2. Select the applicable folder in the tool menu.
  3. Select the document(s) you want to print.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Print to PDF.
    The Print to PDF window appears.
  6. Select the items you want to print:
    • Document details
    • Contents
    • Binders
    • Revisions
    • Links
    • Communications
    • Metadata
    • Workflows
    Tip: Click on the Select all checkbox to select all available items.
    Note: The available items correspond to the selected document(s).
  7. Click Print.
The PDF is saved to your download folder.
