Promote major version
You can promote the last revision to a major version:
  1. Click Files in the toolbar.
  2. Select the applicable folder.
  3. Select the document you want to promote.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Promote major version.
    The Promote major version window appears.
  6. Click OK to confirm.
  • A pop up window informs you that the major revision is promoted.
    If applicable, click Send notification in the pop up window to inform users by email.
  • The updated document is displayed in the content pane.
    Example: .
