Promote major version
You can promote the last revision to a major version:
- Click Files in the toolbar.
- Select the applicable folder.
- Select the document you want to promote.
- Click the ellipsis button at the top of the content pane.
A context menu pops up.
- Click Promote major version.Note: This option is only available when Use minor and major versions is enabled in
The Promote major version window appears.
- Click OK to confirm.
- A pop up window informs you that the major revision is promoted.
If applicable, click Send notification in the pop up window to inform users by email.
- The updated document is displayed in the content pane.
Example: .
