Reassign a project member to a task
You can reassign a project member to a task:
Click Tasks
in the toolbar.
- Click Open tasks in the tool menu to display your incomplete tasks.
- Click on a task to open a window that displays the details for that task.
- Depending on the task status, you can choose one or more assignees.
Click Submit.
A pop up window informs you that the actor is successfully set.
- Click Reassign task.
The Reassign task window appears.
- Select the applicable user, or perform a search.
Note: The reassignable user must have the same role membership as the assigned user.
Click Reassign to transfer the tasks.
A pop up window informs you that the task is successfully reassigned.
- Click the X icon to close the window.
