Release a workflow
You need to release a workflow in order to activate it:
  1. Click Workflows in the toolbar.
  2. Select a workflow folder in the tool menu.
  3. Select a workflow in the content pane.
  4. Click Edit.
    The Edit window appears.
  5. Update the Status to Released.
  6. Click Edit.
    A pop up window informs you that the workflow is successfully edited.
Important: Once a workflow is released and in use, you can not edit the workflow any longer. If you want to edit the workflow, you first need to create a copy of the workflow.
