You can remove an attached workflow:
Click Administration
in the toolbar.
Click Project setup.
Click on the applicable workflow
icon next to a folder in the content pane.
The Edit attached workflows window appears.
Click the X icon next to the workflow you want to remove.
The Detach workflow window appears.
If applicable, enable Detach this workflow from all subfolders of this folder.
Click Detach.
A pop up window informs you that the workflow is successfully detached from the folder.
