You can restore an archived project:
Log into Bricsys 24/7 on the login page.
All projects are displayed.
Click My projects
My projects are displayed.
Select project status Archived from the drop-down menu below the project bar.
Select a project in the content pane.
- Click Restore project.
The Restore project(s) window appears.
Click Confirm.
A pop up window informs you that the project is successfully restored.Tip: Select project status Active to display the active projects.
