Revert to a snapshot
You can revert to a snapshot to restore access rights:
  1. Click Administration in the toolbar.
  2. Click Project setup.
  3. Click the ellipsis button at the top of the content pane.
    A context menu appears.
  4. Click Revert to snapshot.
    The Revert to snapshot window appears.
  5. Select the applicable snapshot.
  6. Click Revert.
A pop up window informs you that the folder access is reverted.
