Roles
Roles
allows you to:
- view roles
- sort role names Tip: Click on a column header to sort the items in that column.
- filter roles on name with the filter buttons
in the content pane
- add, edit, or delete roles
- categorize specific project members into a role and manage the access rights.
Different roles can be set up per project. Typical examples of roles are:
- Administrators
- Architects
- Engineers
- Contractors.
