Roles
Roles allows you to:
  • view roles
  • sort role names
    Tip: Click on a column header to sort the items in that column.
  • filter roles on name with the filter buttons in the content pane
  • add, edit, or delete roles
  • categorize specific project members into a role and manage the access rights.
Different roles can be set up per project. Typical examples of roles are:
  • Administrators
  • Architects
  • Engineers
  • Contractors.
