Search in a project
Bricsys 24/7 contains a search function for the entire project.
Perform a quick search in a project
- Select a project.
- Enter the first 3 characters of the document or folder name you are looking for in the search bar.
The results appear in a pop up window.
- Click the applicable document to open the document details, or click the applicable folder to open the folder in the content pane.
Note: You can use wild cards in the search function:
- The asterisk (*) wild card matches a sequence of characters.
- The question mark (?) wild card matches any character.
Perform an advanced search in a project
- Select a project.
- Click on the slide control icon
on the right side of the search bar.
The Advanced search window appears, including specific search criteria to narrow down the results.
- Click Documents to perform a search of the documents:
- Enter or select the appropriate search criteria.You can search:
- by title
- by description
- by extension
- by status
- by upload date
- by ownerTip: Choose Select contact to perform a search by author.
- per folder
- If applicable, click Add meta data filter.
Select the appropriate metadata and click OK.
- Click Search.
- Check the search results.
- If applicable, click Refine search to adjust the search criteria, and perform a new search.
- Click Communication to perform a search in the communication:
- by subject
- by message content
- by sender
- by receiver
- by type of communication
- per folder
- by upload date
- Click Search.
