Select a project
You can quickly select a project:
  1. Click on the Bricsys 24/7 logo in the project bar.
    A project list is displayed.
  2. Select a project in the list to open the project.
    Note: You can open only one project at the same time.
    Note: If the project administrator has enabled two-factor authentication for the project, you need to enter a token from your token card to log in to the project.
