Set the project size limit
You can set the project size limit:
  1. Log into Bricsys 24/7 on the login page.
    All projects are displayed.
  2. Click My projects.
    My projects are displayed.
  3. Select a project in the content pane.
  4. Click the ellipsis button at the top of the content pane.
    A context menu pops up.
  5. Click Manage project size limit.
    The Manage project size limit window appears.
  6. Enable Limit project size.
    The Limit field appears.
  7. Enter the applicable project size limit.
  8. Click OK.
A pop up window informs you that the project size limit is successfully set. The project size is displayed in the content pane.
