Set up a project
This chapter informs you how to get a project up and running.
You can set up a project from the beginning:
  1. Create a new project
  2. Edit the project settings
  3. Create the folder structure
  4. Define roles
  5. Update access rights
  6. Add users and send an invitation mail.
As an alternative, you can create a copy of an existing project and select the options you want to copy to the new project.
Important: Only the project administrator can create a new project, or copy an existing project.
Note: A customer can have multiple project administrators, managed by our support team.
