You can show or hide columns in the content pane:
Click Files
in the toolbar.
Click on a document folder
in the tool menu.
Click
at the top right corner of the content pane.
A drop-down menu appears.
Note: The available columns correspond to the metadata linked to the selected document folder.
- Select or deselect the columns you want to show or hide in the content pane.
Example: The Inspector column displays the number of available communications, workflows, and attachments.
Note: A red dot next to a workflow icon indicates that an active workflow task is assigned to you.
The selected columns are displayed in the content pane.
