Switch between the old and new user interface
You can switch between the old and new user interface:
- Log into Bricsys 24/7.
- Click on the profile icon/picture on the right side of the project bar.
If you want to switch from the old to the new interface:
- Select Yes from the drop-down menu under Use new Interface.
- Click Save.
A pop up window informs you that the changes are successfully saved.
If you want to switch from the new to the old interface:- Click Profile settings.
- Click Personal settings.
- Select No from the drop-down menu under New interface settings.
- Click Save changes.
A pop up window informs you that the details are successfully changed.
- Restart your project for the changes to take effect.
