Switch between the old and new user interface
You can switch between the old and new user interface:
  1. Log into Bricsys 24/7.
  2. Click on the profile icon/picture on the right side of the project bar.
  3. If you want to switch from the old to the new interface:
    1. Select Yes from the drop-down menu under Use new Interface.
    2. Click Save.
      A pop up window informs you that the changes are successfully saved.
    If you want to switch from the new to the old interface:
    1. Click Profile settings.
    2. Click Personal settings.
    3. Select No from the drop-down menu under New interface settings.
    4. Click Save changes.
      A pop up window informs you that the details are successfully changed.
  4. Restart your project for the changes to take effect.
