You can synchronize between Bricsys 24/7 and the third-party app LetsBuild:
Click Administration
in the toolbar.
Click Project setup.
Select the applicable folder in the content pane.
Click the ellipsis button
at the top of the content pane.
A context menu appears.
Click Sync to LetsBuild.
The Sync folder: Documents window appears.
- Enter your LetsBuild Username and Password.
Click Next to set up and use synchronizations.
Select a project and a folder.
Click Sync.
- A pop up window informs you that one folder is synced to LetsBuild.
- A sync icon is added to the folder in the content pane.
