Transfer a contact
You can transfer a contact to another address book:
  1. Click Address Book in the toolbar.
  2. Select an address book in the tool menu.
  3. Select a contact in the content pane.
  4. Click Move contact.
    The Move window appears.
  5. Select the address book where you want to transfer the contact to.
  6. Click Move.
    A pop up window informs you that the contact is successfully moved.
