You can transfer an organization to another address book.
Click Address Book
in the toolbar.
Select an address book in the tool menu.
Select an organization in the content pane.
Click the ellipsis button
at the top of the content pane.
A context menu appears.
- Click Move organization.
The Move window appears.
Select the address book where you want to transfer the organization to.
Enable Include all organization members if you also want to transfer the contacts of the selected organization.
Click Move.
A pop up window informs you that the organization is successfully moved.
