Unlock a document You can unlock one or more documents: Click Files in the toolbar. Select the applicable folder. Select the document(s) you want to unlock. Click the ellipsis button at the top of the content pane. A context menu pops up. Click Unlock . A pop up window informs you that the documents are unlocked. The documents are displayed as unlocked in the content pane.Example: .
