Upload a document
You can upload one or more documents:
  1. Click Files in the toolbar.
  2. Click Upload.
    A modal window appears.
  3. Select the document(s) you want to upload.
  4. Click Open (Windows) or Choose for Upload (Mac).
    The Choose a folder to upload to... window appears.
  5. Select the folder you want to upload to.
  6. Click Confirm.
    The Uploading window appears.
  7. If applicable, add a status and a description per document, and select the appropriate options.
    Note: The available document statuses correspond to the project settings.
    Note: If the file name already exists in the folder you want to upload to, you can:
    • Tick the upload this document as a copy checkbox to upload the document as a separate file. If applicable, enter the required options.
    • Tick the Replace last revision checkbox to upload the document as a new revision.
    Note: If you are uploading multiple documents, you can click apply data to all uploads to copy the added information to all documents you want to upload.
  8. Click Upload.
A pop up window shows the upload progress and informs you that the documents are successfully uploaded. The uploaded documents are visible in the content pane.
Note: As an alternative, you can first select a folder in the tool menu, before you click on Upload.
Note: The maximum upload size is 20 GB.
Tip: If you want to upload a lot of documents simultaneously, you can use the Bricsys 24/7 Transfer Tool.
