Upload a zip file
You can upload one or more zip files:
  1. Click Files in the toolbar.
  2. Select the folder you want to upload to.
  3. Click Upload.
    A modal window appears.
  4. Select the zip file(s) you want to upload.
  5. Click Open (Windows) or Choose for Upload (Mac).
    The Uploading window appears.
  6. If applicable, add a status and a description per document, and select the appropriate options.
    Note: The available document statuses correspond to the project settings.
    Note: If you are uploading multiple zip files, you can click apply data to all uploads to copy the added information to all documents you want to upload.
    Note: If the file name already exists in the folder you want to upload to, you can:
    • Tick the upload this document as a copy checkbox to upload the zip file as a separate file. If applicable, enter the required options.
    • Tick the Replace last revision checkbox to upload the zip file as a new revision.
  7. Tick the Unzip file after upload checkbox per zip file.
  8. Click Upload.
A pop up window shows the upload progress and informs you that the documents are successfully uploaded. The unzipped files are displayed in the content pane.
