You can upload one or more zip files:
Click Files
in the toolbar.
Select the folder you want to upload to.
- Click Upload.
A modal window appears.
Select the zip file(s) you want to upload.
Click Open (Windows) or Choose for Upload (Mac).
The Uploading window appears.
If applicable, add a status and a description per document, and select the appropriate options.
Note: The available document statuses correspond to the project settings.
Note: If you are uploading multiple zip files, you can click apply data to all uploads to copy the added information to all documents you want to upload.
Note: If the file name already exists in the folder you want to upload to, you can:
- Tick the upload this document as a copy checkbox to upload the zip file as a separate file. If applicable, enter the required options.
- Tick the Replace last revision checkbox to upload the zip file as a new revision.
Tick the Unzip file after upload checkbox per zip file.
Click Upload.
A pop up window shows the upload progress and informs you that the documents are successfully uploaded. The unzipped files are displayed in the content pane.
