Work with relations
A relation is a tree structure that can be used as a field within a form to get a structured overview of your data.
The Relations tool allows you to:
- create new relations
- edit relations
- delete relations.
You can add a relation:
- A pop up window informs you that the folder is uploaded.
- The new relation is displayed in the content pane.
