Admin Access
Define the administrator categories an administrator has access to.
Access
The access is split up like the categories in the administration app.
Change the settings of the project
Add, edit or delete the folders
Add, edit or delete users and roles
Set access on the folders
Set access on forms
Set access on third party applications
Create reports of the project activity
Restore or definitely items
Set access for administrators
Note: Note that the you cannot have folder structure access without folder access.
Note: Note that the project owner always has all admin access.
