Overview
Only the administrators of a project can see and use this App. This administrator app gives administrators the possibility to set up and manage the project environment. The app is divided in different categories.
Settings
Fill in or edit the basic information of the Project, ask for support and change project settings.
Structure
Add or edit the project structure (project tree).
Relations
Add or edit relation structures.
Users
Invite users and assign them to their corresponding roles.
Roles
View, add or edit roles and their specifications.
Folder access
View, add or edit access rights to roles for folders.
Admin access
Specify to which sections an administrator has access.
Table administration
Change access rights for forms.
Audit report
Search through every Action / Object / User in the activity log of the project.
Recycle bin
Restore deleted objects / folders /... from the recycle bin to your project or decide to delete them definitely.
