Roles
View, edit or add roles and their specifications.
Role inspector
Number of people in the role
Permission to see other users
Permission to see revisions
Permission to see their profile
Mail list of the people who are assigned to this role
Add role
You can create a new role or copy an existing role from another project.
Create a new role
  1. Name the role
  2. Optionally
    • Use as a mail list
      If you want to send an instant message to all the members of the role
      As project administrator you can setup roles so they can be used as maillists. Whenever you modify an existing role or add a new role, you can indicate whether this role should be used as a maillist by selecting the check box use as maillist. Once this option is checked every next notification or annotation can be sent automatically to all users who are members of this particular role. E.g. If for the role ''Engineers'' the admin enables the checkbox use as maillist all members of the role ''Engineers'' will be notified (instead of notifying each user of the role ''Engineers'' separately).
    • Members of this role can see other members
      If the users in this role cannot see other members they are not able to send notifications to other users.
    • Members of this role can view revisions
    • Members of this role can change their profile
      The members can change everything int their profile: profile picture, email, password, folder subscriptions…
Import a role from another project
  1. Searching existing roles from other projects (Please note that folder access rights will not be copied while importing any role. The folder structure is usually different in every project and folder access rights would not always be compatible if they were all copied.)
  2. Optionally import members of the role (Please note that folder access rights will not be copied while importing any member. The folder structure is usually different in every project and folder access rights would not always be compatible if they were all copied.)
