Create closed polylines, defined by surrounding entities using the Command line. Options
allow you to pick an internal point, specify the boundary set, and detect islands. See
the BOUNDARY command to access similar functionality using a dialog box.
Original entities:
Internal point
Resulting polylines:
Methods to create a boundary
There is one method to begin creating a boundary:
Internal point
Internal point
Begin creating boundaries by specifying a point inside an enclosed area for
which you want to create a boundary. You can continue picking additional points
until you press Enter to end the command.
Alternate options: [Advanced/Undo]
Options within the -BOUNDARY command
After you begin creating boundaries, the following options may be available:
Advanced
Choose to modify boundary options or island detection.
Boundary
Specify where BricsCAD should search for entities that
make up the boundary.
New: create a new selection set of entities that
Everything: select all entities in the current
viewport.
Island
Specify the island detection. An island is an enclosed
area inside a boundary.
Yes: treat every island as a boundary.
No: create a boundary of only the outermost
entities.
Outer only: ignore the innermost areas. A
boundary is created between the outermost area and islands.
Original entities:
Internal point
Yes:
No:
Outer only:
Exit
Return to the previous prompt.
Undo
Undo the last internal pick point and continue picking points to specify
additional enclosed areas.
-BOUNDARY command - BricsCAD | Bricsys Help Center
