-DESIGNTABLEEDIT command
Edits design tables.
Note: This command can be entered transparently during the commands (‘designtable).
Options within the command
eXport
Exports the content of a design table entity in .csv format file.
Replace
Replaces the content of a design table with data from a .csv format file.
Delete
Deletes a design table.
Configurations
Creates, removes, or views configurations.
Save current
Creates a new configuration as a copy of an existing one.
Remove
Removes a configuration.
? to list
List the names of design tables attached to the current drawing.
Parameters
Manages parameters:
Unlink
Unlinks parameters from the design table.
Link
Links parameters to the design table.
Note: (*) to link all: restores all initially existent but removed parameter links.
Clear expressions
Clears expressions (values and formulae) from parameters.
? to list columns
Lists parameters.
Apply configuration
Creates a new row using the current values of variables.
? to list
Lists design tables attached to the current drawing.
