-INSERTLAYOUT command
Inserts a named layout of a drawing, as a Block Reference, in the current Paper Space.
Specify the drawing path name to export the layout from and the layout name, together with the insertion point. A Block reference that replicates the entities in the layout will be inserted in the current Paper Space.
Note: The command is only available in Paper Space.
