-INSERTMULTIPLELAYOUT command
Inserts multiple layouts, as Block References, in the current Paper Space via command line.
Inserts named layouts of multiple drawings in the current Paper Space as Block References.
Note: The command is only available in Paper Space.
Method
Enter the margin to be used between viewports in the Paper Space.
Note: A positive value, or zero, is needed.
Enter the list of drawings to export layouts from, by specifying the drawing path names one by one. When finished, press Enter with an empty string to continue with exporting.
The -INSERTMULTIPLELAYOUT command now loops over the files and asks you to enter the layout name for each drawing.
Specify the base point and second point for the Block References.
