-PARAMETERS command
Manages dimensional-constraint parameters.
Creates, edits, renames, and deletes parametric equations made of dimensional constraints and user-defined variables; works at the Command line.
Options
Lists all dimensional constraints and user variables in the current drawing, showing the name, expression and current value of each dimensional constraint or user variable.
New
Creates a user variable.
Edit
Edits the expression for the dimensional constraint or user variable.
Rename
Renames a dimensional constraint or user variable.
Delete
Deletes a dimensional constraint or user variable.
Properties
Sets the lower and the upper bounds for the parameter.
Lower bound
Defines the lower value for the parameter.
Upper bound
Defines the upper value for the parameter.
Note: The upper and lower bounds are taken into account in dynamic operations, like DMMOVE and ROTATE3D.
