AMEDGESYM command
Creates an edge symbol.
Icon:
Method
Select the object to attach the edge symbol to and specify the points for its location.
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Note: These dimensions are compatible with the legacy AutoCAD® Mechanical application.
Note: The dimensions will be added to the AM_5 layer.
Note: After opening a drawing that contains mechanical entities, filling other drawings with mechanical-related data will be done on-demand in contrast to previous versions. It will be possible when a user copies the mechanical-related entities to the vanilla drawing. In case of copying entities that are not related to the mechanical data, a vanilla drawing will not be filled with mechanical data.
Note: When you open a drawing that contains mechanical entities, but the LOADMECHANICAL2D system variable is OFF, a warning bubble is displayed at the status bar that describes the situation and provides a hyperlink to immediately enable and load the mechanical 2d modules.
After creating the edge symbol with the AMEDGESYM command, its properties can be configured in the Properties panel:
Symbol
- Drafting standard
- Displays the drafting standard.
- Standard revision
- Displays the standard revision.
- Scale
- Sets the note scale.
- Majority symbol
- Chooses to display or to not display the majority symbol.
Requirements
Defines the edge symbol requirements.
- Direction
- Defines the position of the Undefined size sign.
- Defined
- The sign will be on a position defined by the Undefined size direction property.
- Undefined
- The sign will be on an undefined (middle) position.
- Undefined size
- Defines the edge:
- None
- Defines no requirements for the edge type. If available, upper and lower limits are displayed.
- Burr or passing permitted
- Defines the edge type as burr or passing.
- Undercut required
- Defines the edge type as undercut.
- Undefined size direction
- Defines the position of the undefined size sign.
- Upper limit
- Defines the upper value by typing it in the box or by selecting it from the drop-down list.
- Lower limit
- Defines the lower value by typing it in the box or by selecting it from the drop-down list.
- All around
- Adds the all around mark to the edge symbol.
- Standard label
- Displays the standard revision next to the symbol.
Leader
- Primary arrowhead
- Sets the leader style.
