CONVTOSOLID command
Converts entities to solid entities.
Converts valid 2D and 3D entities to 3D Solid entities. Valid entities include:
  • Watertight 3D Mesh
  • Watertight 3D Surface
  • 3D Polygon Mesh
  • 3D Polyface Mesh
  • Circle with thickness
  • Closed Polyline of non-zero thickness and uniform width
Method to convert to solid
There is one method to convert entities to 3D Solid entities:
  • Select entities
Select Entities
Begin converting an entity to a 3D Solid entity by selecting a valid entity then:
Select entities
Select another valid entity or press Enter to complete the command.
Note: The BIM data and GUID are maintained after converting.
