DEPARAMETRIZE command
Deparametrizes the selected entities.
Deparametrizes the selected entity. This command can also be used with parametrized 2D entities.
Note: Make sure the parametrized entities are converted to blocks before running the command.
Options within the command
Once the command is initiated, options regarding the selection of entities to deparametrize are available.
- Select block references to make static
- Select block references in the drawing to deparametrize. Only the selected entities will be made static.
- Entire drawing
- Deparametrizes all entities in the current drawing.
Note: To verify whether the block reference is made static or not, check the properties of the selected block in the Properties panel.
