DMCONCENTRIC3D command
Applies a concentric constraint between two circular subentities of 3D entities.
Icon:
Method
The concentric constraint could be applied between any two circular surfaces or circular edges of a 3D entities (cylindrical (circular or elliptical), spherical or conical surfaces and their edges) or between a subentity of a 3D entity and a 2D circular entity.
Select the two circular subentities between which the concentric constraint will be applied. Press the TAB key to select obscured geometry.
Options within the command
WOrld
Allows you to select the WCS subentity as an argument.
BLock
Allows you to choose, as an argument, the subentity of the coordinate system of the block.
