DMRADIUS3D command
Applies a radius constraint to circular 3d entities or subentities.
Icon:
Applies a radius constraint to circular edges, cylindrical surfaces, spheres and tori by indicating the radius value or using geometry-driven.
Method
Select a cylindrical or sphere surface or a circular edge and specify the radius value or keep the geometry-driven. In case of selecting a torus surface, you can constrain the rotation radius or/and the tube radius.
Press the TAB key to select obscured geometry.
Options
- Rotation radius
- Specify the rotation radius to be constrained.
- Tube radius
- Specify the tube radius to be constrained.
- Geometry-driven
- Accept the current value and create a geometry-driven constraint.
Note: The constraint value displays when hovering over the 3D radius constraint widget.
Note: You can set upper and lower bounds in the Mechanical Browser panel, which are taken into account in dynamic operations, like DMMOVE and ROTATE3D.
