MOVEEDATA command
Moves extended entity data from one entity to one or more others.
Icon:
Method
Enter the name of the application to which the entity data belongs, select the entity from which to move Entity Data and one or more entities to which Entity Data will be moved (that will receive the edata). Extended Entity Data can be created with EditEData command.
Options
- ? to list application names
- Lists names of applications loaded in the current drawing.
