POINTCLOUDALIGN command
Rotates the point cloud to optimally align it with the X and Y axes.
Icon:
Rotates the point cloud to optimally align it with the X and Y axes in the world coordinate system or creates an UCS aligned with the point cloud. This enables you to efficiently create and edit entities relative to the point cloud using common tools such as orthogonal and polar tracking.
Options within the command
- Select point cloud entity
- Allows you to select a point cloud entity if the current drawing has more than one point cloud attached.Note: If the current drawing has only one point cloud attached, it is automatically selected for the align operation.
- First corner point
- Specifies the first corner of a rectangular selection window.
- Specify opposite corner
- Specifies the opposite corner of a rectangular selection window.
- Ucs
- Creates an UCS aligned with the point cloud.
- Yes
- Saves the UCS using the point cloud name or a user-specified name.
- No
- UCS is created without saving.
- Rotate
- Rotates the point cloud to optimally align it with the X and Y axes in the world coordinate system.
