POINTCLOUDGEOGRAPHICLOCATION command
Sets the geographic location based on point cloud.
Sets the geographic location based on point cloud; sets point cloud transform based on geographic location; relatively aligns two point clouds.
Note: Only LAS and LAZ file formats can make use of this functionality.
Method
There are three methods:
  • Geolocation
  • Transform
  • Relative
Options within the command
Geolocation
Allows to set a geographic marker in the DWG based on a point cloud with geographic location.
Transform
Updates the point cloud transform based on a geographic location in the DWG, as well as the geographic information in the point cloud.
Relative
Relatively aligns two point clouds if both contain a geographic location.
