Creates a closed, four-sided rectangular polyline Insert link to Polyline Entities
article in the shape of a rectangle, square, and variants with chamfers or fillets.
First corner
Second corner
Length
Width
Methods to create a rectangle
This command has 5 methods to begin creating a rectangle:
Select first corner of rectangle
Rotated
Square
Area
Dimensions
Additional options: [Chamfer/Fillet/Elevation/Thickness/Width of line]
Begin creating a rectangle by specifying a corner of a rectangle then:
Other corner of rectangle:
Specify the opposite corner of the rectangle. The
rectangle is drawn parallel to the x and y axes.
Rotated
Additional options:
[Chamfer/Fillet/Rotated/Square/Elevation/Thickness/Width of
line/Area/Dimensions]:
Rotation angle for rectangle
Specify the rotation angle of the rectangle.
Rotation angle
Square
Begin creating a rectangle by specifying a corner of a square then:
Additional options [Chamfer/Fillet/Rotated/Elevation/Thickness/Width of
Second corner of square
Specify a corner along the same side of the square
to define its length and angle.
Area
Begin creating a rectangle by specifying its area then:
Calculate rectangle dimensions based on
[Length/Width]
Choose whether to use the length or width to
calculate the dimensions for the rectangle.
Length: enter rectangle length
Width: enter rectangle width
Dimension
Begin creating a rectangle by specifying its length then:
Width to use for rectangles
Specify the width of the rectangle.
Specify the first corner of the rectangle.
Additional options:
Options within the RECTANG command
After you begin creating a rectangle, the following options may be available:
Chamfer
Specify the first chamfer distance to use for all rectangles then:
Additional options [turn chamfer Off, use Default setting]
Second chamfer distance to use for all rectangles
Specify the second chamfer distance to use for all
rectangles
First chamfer distance
Fillet
Specify the fillet distance to use for all rectangles.
Additional options [turn fillet Off, use Default setting]
Fillet radius
Elevation
Specify the height above the xy-plane to use for all rectangles.
Additional options: [use Default]:
Width of line
Specify the width of the rectangle line segments. All segments have the same
width.
Thickness
Specify the thickness of the rectangle line segments. All segments have the
same thickness.
