SECTIONPLANE command
Creates section entities.
Icon:
Creates section entities from 3D solids, 3D surfaces, polyface meshes and 3D faces. This command helps to see inside a 3D entity.
Note: New created section planes have their Clip Display
status set to on. As section planes are entities, they can be edited and
deleted.
Options within the command
- Specify start point
- Specifies the starting point of a 2D section plane.
- select Face
- Select the planar face of a 3D solid.
- Draw
- Define the section plane by two ore more points. Draws L and U-shaped section planes.
- Orthographic
- Places a section plane entity in one of the six standard drawing orientations, relative to the current UCS.
