BricsCAD Communicator - Supported export file formats
Supported export file formats:
Windows
  • 3D PDF: .pdf
  • ACIS: .asab, .asat, .sab, .sat
  • CATIA v4: .model
  • CATIA v5: .CATPart, .CATProduct
  • IGES: .iges, .igs
  • STEP: .step, .stp
    The following export protocols can be specified; AP203, AP214, AP242
  • VDA-FS:.vda
  • XCGM: .xcgm
  • Parasolid:.xmt_bin, .xmt_txt, .x_b, .x_t
    Export to Parasolid format is possible if:
    • pskernel.dll is available in InterOp, e.g. in a folder accessible through PATH enviroment variable.
    • P_SCHEMA environment variable points to the schema folder which can be found next to pskernel in its original installation. The folder name may slightly differ, e.g. in SolidWorks 2018 it is schema_18.
    • pskernel.dll version is earlier than the major version supported by InterOp, the EXPORTPARASOLIDFORMATVERSION system variable has to be set to a (lower) version that pskernel library supports.
Linux
  • 3D PDF: .pdf
  • CATIA v4: .model
  • CATIA V5: CATProduct, .CATPart
  • IGES: .iges, .igs
  • STEP: .step, .stp
  • VDA-FS:.vda
  • XCGM: .xcgm
Mac
  • CATIA v4: .model
  • IGES: .iges, .igs
  • STEP: .step, .stp
  • VDA-FS:.vda
Note: When the EXPORTPRODUCTSTRUCTURE system variable is set, you can export a BricsCAD® assembly with mechanical components as a file with product structure.
Note: If the assembly contains hidden parts, you can decide how to process the export hidden parts by setting the EXPORTHIDDENPARTS system variable.
Note: All other related system variables which controls the export file types are listed in the Related variables.
