Loading and unloading CUI files
When you install BricsCAD, the default CUI files are copied to the Support folder (see BricsCAD User Files).
When you launch BricsCAD the first time, the default.cui file is loaded automatically.
There are two procedures to load a CUI file:
- Load main CUI file: replaces the currently loaded main CUI file.
- Load partial CUI file: partially replaces the content to the currently loaded main CUI file.
Loading a main CUI file
- Launch the CUSTOMIZE command.
The Customize dialog box appears.
- In the File menu, choose Load main CUI file ... .
The Select main CUI file dialog box displays the content of the Support folder.
- Select a CUI file, then double-click or click the Open
button.
The selected CUI file is loaded.
- Close the Customize dialog.
Loading a partial CUI file
- In the File menu, choose Load partial CUI file
The Choose a customization file dialog box displays the content of the Support folder.
button.
The content of the selected CUI file is appended: definitions which are different from the ones in the main CUI are used.
Unloading a partial CUI file
- Click the Menus tab.
- Right-click the partial CUI name and choose Unload <PartialCuiName> in the context menu.
Managing customization groups
- Launch the MENULOAD command.
The Customization groups dialog opens.
- (Option) To load a partial CUI file, click the browse button (
) to select a partial CUI file, then click the Load button.
- (Option) To unload a partial CUI file, select the partial CUI file in the Loaded Customization Groups list, then click the Unload button.
- Click the Close button to stop.
